AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Adjustable Bar Scale
5 REPLIES 5
Victoria12
523 Views, 5 Replies
I work with Autodesk Map 3D and I was wondering if the latter provides a bar scale that will adjust automatically to the size of the plotting paper.
Thanks a million!
5 REPLIES 5
Soocom1
in reply to: Victoria12
Not currently.
I have had to build one useing the Field comand linked to the viewport. The scale itself remains static, but the numbers change.
This is also linked to the scale at the bottom if you are useing A-cad 2008,09,or 10.
Victoria12
Thank you so much for replying.
Victoria12
I am trying to create an adjustable Bar Scale using the field command, as advised by Soocom1 above.
I chose 1"= #' from the field menu. It gave me the following: 1" = .2154' .
In the field expression box, I got the following:
%<\AcVar.16.2 PlotScale \f "1\" = %lu2%zs12%ct9[0.0833333333333333]'">%
The Edit Scale List is set to 1"=1" where 1' of paper is equal to 0.08333333 drawing feet.
Where does the number 0.2154 come from?
Thanks a million!
Victoria12
Help..anybody?
Thanks a million!
mekohler
2013 has a scale bar tool.
”Boost
