AutoCAD Map 3D General Discussion
Active Contributor
Victoria12
Message 1 of 6 (349 Views)
Adjustable Bar Scale
349 Views, 5 Replies
05-28-2009 08:48 AM
I work with Autodesk Map 3D and I was wondering if the latter provides a bar scale that will adjust automatically to the size of the plotting paper.
Thanks a million!
Valued Contributor
Soocom1
Message 2 of 6 (349 Views)
Re: Adjustable Bar Scale
05-28-2009 10:34 AM in reply to: Victoria12
Not currently.
I have had to build one useing the Field comand linked to the viewport. The scale itself remains static, but the numbers change.
This is also linked to the scale at the bottom if you are useing A-cad 2008,09,or 10.
Active Contributor
Victoria12
Message 3 of 6 (349 Views)
05-28-2009 10:44 AM in reply to: Victoria12
Thank you so much for replying.
Active Contributor
Victoria12
Message 4 of 6 (349 Views)
05-28-2009 12:07 PM in reply to: Victoria12
I am trying to create an adjustable Bar Scale using the field command, as advised by Soocom1 above.
I chose 1"= #' from the field menu. It gave me the following: 1" = .2154' .
In the field expression box, I got the following:
%<\AcVar.16.2 PlotScale \f "1\" = %lu2%zs12%ct9[0.0833333333333333]'">%
The Edit Scale List is set to 1"=1" where 1' of paper is equal to 0.08333333 drawing feet.
Where does the number 0.2154 come from?
Thanks a million!
Active Contributor
Victoria12
Message 5 of 6 (349 Views)
05-30-2009 09:43 AM in reply to: Victoria12
Help..anybody?
Thanks a million!
Active Contributor
mekohler
Message 6 of 6 (193 Views)
08-09-2012 08:35 AM in reply to: Victoria12
2013 has a scale bar tool.
