AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
ADF format
2 REPLIES 2
DiegoP1978
484 Views, 2 Replies
ADF format
Hello everybody.
Maybe someone can help me. I've two questions.
1)To create a connection ArcGis is neccessary to have an ArcGis lycense?
2) I wanto to import some files in .adf format (Arc/INFO Grid File is it possible with AutoCAD Map 3D? How?
Diego
Tags (2)
2 REPLIES 2
to your first question ... there are already some threads there: >>>click<<<
The question about how to connect to an ADF-file: use command _MAPCONNECT, find rasterfiles as type and there you can now connect to your ADF-file(s). Important: It may depend on your version of Map3D if that is already built in or not.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Thx alfred.
Now it's working.
The problem is that in the translation from english in italian
It sounds like to connect to immagine and not like connect to rasters (like immagine but also .asc .esri coverage ...)
thx a lot
Danke!!
”Boost
