AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Adding Text in a Map3D Expression
10 REPLIES 10
Message 1 of 11
rl_jackson
1394 Views, 10 Replies
I'm playing around with the FEMA NFHL Database and have some text set up to provide the Flood Zone of the Polygon as shown below.
Now as you can see I'm getting an invalid expression, when I go to add the word Zone to the front of the data. Is there a way to do this?
Rick Jackson
Survey CAD Technician VI
10 REPLIES 10
Message 2 of 11
Murph_Map
in reply to: rl_jackson
Try this
Concat ('Zone',  FLD_ZONE)
Murph
Supporting the troops daily.
Message 3 of 11
rl_jackson
in reply to: Murph_Map
Thanks Murph,
I can definitely see I'm going to need a book or something for this - Anything you'd recomment?
Rick Jackson
Message 4 of 11
Murph_Map
something like
CONCAT(First_Name, ‘ ‘Last_Name,’\P’ ‘Address: ‘, Street_number, ‘ ‘, Street_name, ‘ ‘, Suffix)
This example produces a label like this:
John Smith
Address: 123 Maple Street
Try the help button and the getting Started at the bottom of the dialog for a few examples.
Murph
Message 5 of 11
parkr4st
Or this
 ( Concat ( 'Cut Area No. ',  CutAreaNo, '\P' ,(Concat ( 'Harvest Year is ' ,Year ))))
to get this
Cut Area No. 2
Harvest Year is 2013
'    ' surround strings, add spaces here for neatness and readibility
Parenthesis work by the general rules of algebra, must have open and close pairs
commas seperate items
Dave
Message 6 of 11
dnietubicz
in reply to: parkr4st
I'm using this expression to get the owner name, mailing address and parcel number based on the fields from our GIS data. CONCAT ( Owner_Name , '\P', Owne_Name_ , '\P', Mailing_Ad , '\P', Mailing__1 , '\P', Mailing_CS , '\P', PARCELNO ) The problem I am having is that some of the parcels don't have 2 names for the owner or 2 lines of address before the city state and zip, but some of them do. Example of what I get if there is no data available in one of the columns in the table GERONIMO PROPERTIES LLC---------------------------Owner_Name Owne_Name_ 215 FIRST ST N STE 200 Mailing_Ad Mailing__1 WINTER HAVEN, FL 33881 Mailing_CS S14342810000E00010 PARCELNO Example of what I get if there is data available in all of the columns in the table. SPRINT-FLORIDA INC--------------------------------------Owner_Name SPRINT CORPORATION Owne_Name_ PROPERTY TAX DEPT Mailing_Ad P O BOX 7909 Mailing__1 OVERLAND PARK, KS 66207-0909 Mailing_CS C233428A0000610000 PARCELNO Is there anyway to do some sort of "IF" statement, that will ignore what is being asked for if the data tables column is empty? Basically, I'm trying to have blank lines. Thanks, Doug
Message 7 of 11
I use this for returning an empty string to a label if a street name in our road table (layer) is named 023.
 If ( ' Street LIKE ''023'' ' , ' ',  Street  )
The if statement requires a string for the first parameter (go figure), so any true/false evaluation statement must have single quotes around it to get the if statement to work.
In the above example, Street is a text property of the road table (layer), Like is the comparison operator, 023 is the text to compare against.Then there is two single quotes, with a space between them, after the first comma to return an empty string (actually a single space) if the Street name is like 023. Finally there is Street after the second comma, which returns the text property Street if Street is not like 023.
Note the 023 is surrounded by two single quotes. This is what I have worked out is requred to get text to be evaluated within single quotes.
So for you try this.
your expression
Give this a try
CONCAT ( Owner_Name , '\P', If ( ' Not Owne_Name_ = '''' ', CONCAT ( Owne_Name_ , '\P'), ' ' ), Mailing_Ad , '\P', Mailing__1 , '\P', Mailing_CS , '\P', PARCELNO )
This should return the second owners name and a carriage return if the second owners name has a value otherwise it should return a space.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 8 of 11
Civil3dMike
Hi Murph, how would you make the expression center justified text.
My expression is: Concat (PID , '\n',  NAME_1) and it displays
45
John Doe
I want it to display:
    45
John Doe
Any help is appreciated.
Mike -
Message 9 of 11
Murph_Map
in reply to: Civil3dMike
In the style label dialog there's a Horizontal Alignments button that lets you center the text.
Murph
Message 10 of 11
Civil3dMike
I am running Civil3d 2011, my style label dialog box looks different than yours and the options for justification are grayed out.
Message 11 of 11
braudpat
Hello
YES it's normal because the FDO Engine is completely NEW in MAP/CIVIL 2012 !
They are many new features ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
