AutoCAD Map 3D General Discussion
Active Member
bkesting
Message 1 of 16 (202 Views)
Adding imagery to Map 3D 2012 file
202 Views, 15 Replies
11-07-2013 01:03 PM
I am a fairly new user of the Map 3D.  We have a map created for our city with all our utilites, zoning, etc. plotted out and we have some very old aerial imagery attached to it.
Just a few months ago, Pictometry flew some new hi-res imagery for me.  I have individual ortho tiles and one large ortho-mosaic.  When I try to install the imagery, it doesn't line up anywhere close to where it should be on the map.  How can I go about getting my imagery and my map lined up?
Thanks for any help
Brian
*Expert Elite*
antoniovinci
Message 2 of 16 (199 Views)
Re: Adding imagery to Map 3D 2012 file
11-07-2013 01:10 PM in reply to: bkesting
Command: _ADERSHEET
Active Member
bkesting
Message 3 of 16 (193 Views)
11-07-2013 01:54 PM in reply to: antoniovinci
Thanks for the suggestion.  I can't quite seem to get it to work right, but I'll keep messing around with that command.
*Expert Elite*
Murph
Message 4 of 16 (184 Views)
11-07-2013 03:17 PM in reply to: bkesting
Check the coordinate system for both the image and your base map/dwg.
Murph
Supportting the troops daily.
Active Member
bkesting
Message 5 of 16 (179 Views)
11-07-2013 03:19 PM in reply to: Murph
Here's how new I am to this product.......how do I find the coordinate system for my base drawing?
*Expert Elite*
Murph
Message 6 of 16 (170 Views)
11-07-2013 03:40 PM in reply to: bkesting
In newer versions it's on the Stataus bar.
On older systems type in _MAPCSASSIGN.
Murph
*Expert Elite*
antoniovinci
Message 7 of 16 (151 Views)
11-07-2013 11:03 PM in reply to: bkesting
As first attempt, I'd try to line up the imagery to the vector, by means of the simple _ALIGN command.
Afterwards, I'd run the "fine tuning" of the powerful _ADERSHEET routine.
*Expert Elite*
Murph
Message 8 of 16 (142 Views)
11-08-2013 03:47 AM in reply to: antoniovinci
Be careful of the rubbersheeting or that command. Do a save of the dwg before you use it and saveas after each move or edit. I have seen too many users end up with trash and no way to get back to the original work.
Murph
Valued Mentor
fieldguy
Message 9 of 16 (127 Views)
11-08-2013 07:29 AM in reply to: bkesting
What format did you receive the orthos in?  The easiest (for alignment purposes) is TIFF images with TFW "world files".
Active Member
bkesting
Message 10 of 16 (124 Views)
11-08-2013 07:31 AM in reply to: fieldguy
My current base map doesn't appear to have any coordinate system applied to it.  It must just be "floating in space".
My ortho imagery (tiles and mosaic) are in .ecw fomat.  (Though I think I can convert them if need be).
Post to the Community
New Post
Need installation help?
