AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Addind a raster image locks up Autocad Map 2012
2 REPLIES 2
526 Views, 2 Replies
I've rebooted, re-installed and nothing changes the fact that when i try and insert a raster image the program locks right up.
I can go back 2009 version and have no problems inserting the same raster.
Anyone have any solutions or experience the same problem?
the raster is a Mr.Sid format file
2 REPLIES 2
nothing really?
AUTODESK are you there?
Alfred.NESWADBA
I'm not Autodesk, but I miss some info of what you have tried yet 😉
  • Have you tried to convert the file to e.g. a TIFF-format, does it then also hang up?
  • What command did you use to reference the image?
  • Have you setup a coordinate-system for your drawing? Have you  tried to insert the image when another coord-sys is assigned to your drawing
  • Have you tried to insert the image into another drawing?
  • Have you installed the latest service-packs for Map3D?
  • Have you tried to start Map3D with another profile (or with another Windows user-account) to mmake sure it's not specific to your current AutoCAD-profile?
  • Have you tried to toogle hardware-acceleration?
...or what did you try up to now?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
