AutoCAD Map 3D General Discussion
Active Member
weiwei75412
Message 1 of 10 (479 Views)
64bit map3d fatal error when create polygon
479 Views, 9 Replies
07-31-2012 08:36 PM
Hi
I have a computer newly installed windows7 64bit,and installed map 3d 2012.with SP. when I was trying to create polygon with command "MPOLYGON" or "MAPLOLYLINETOPOLYGON",MAP3D crashed.it does not matter if the polygons have holes or not,the polygon can be created,but after 2 seconds or when I RIGHT CLICK to see quick menu,CAD crashed immidiately.
I rremembered that there were topics discussing same issue,but I could not find them now.
Can anyone help?
Thanks.
H
Active Member
weiwei75412
Message 2 of 10 (470 Views)
Re: 64bit map3d fatal error when create polygon
07-31-2012 10:00 PM in reply to: weiwei75412
Active Member
weiwei75412
Message 3 of 10 (445 Views)
08-01-2012 05:19 PM in reply to: weiwei75412
Today,I found this:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/MPolygon-select-caushes-crash-fatal-error/td-p/291836...
which addressed the same issue with civil 3D and Map 3D.It looks the Civil 3D proplem solved whith a SP but not the Map 3D 2011 .
I tried change graphic driver to certified version.
turn off rollover tooltips and property ,quick property.no good.
and tried the suggestion on:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18818398&linkID=9240617
no luck.
polygonn can be selected,edited,but can not see the property window.
CAD will crash when I right click with a polygon selected.
Is it a known issue for 64bit Map3D 2012?
Will this be fixed in future?
Hua
Active Member
weiwei75412
Message 4 of 10 (374 Views)
08-15-2012 06:44 PM in reply to: weiwei75412
Nobody has the same issue?
Active Contributor
mekohler
Message 5 of 10 (364 Views)
08-16-2012 07:58 AM in reply to: weiwei75412
I have the same issue, I can't ever open a drawing containing mpolygons.  I've put a request in with Autodesk support.  I will let you know if I they have a solution.
Michael Kohler
Active Member
weiwei75412
Message 6 of 10 (358 Views)
08-16-2012 04:28 PM in reply to: mekohler
I have found some tricks to keep ACAD running:
1.undefine " properties "command,so the properties window will never show up.
2.disable right click short cut menu,in "options"
3.close selection cycling and quick property
4.do not use "quick select" tool.
5.use "list" to check properties.
6.use "adeeditdata" to check and edit  object data.
so far ,these work.
You can create a profile which is set up as above.Then lunch AUTOCAD  using the profile.
Let me know if it works.
Hua
Active Contributor
mekohler
Message 7 of 10 (347 Views)
08-17-2012 09:04 AM in reply to: weiwei75412
If  I set up a profile, will these settings only take place for this profile?  To do this do I log in as the new user and make the changes?  After which if I start Map without logging in, will Map default to normal?
Michael Kohler
Active Contributor
mekohler
Message 8 of 10 (339 Views)
08-17-2012 02:05 PM in reply to: mekohler
Could you list how to create these changes for a single profile.
Thank you,
Michael Kohler
Active Member
weiwei75412
Message 9 of 10 (319 Views)
08-19-2012 04:48 PM in reply to: mekohler
Sorry I am not fimilar with the log in issue,cause I am the only user in my section.
to create a profile :
1.write a LISP  to undefine "properties." Add this LISP to AUTOcad auto load LISP list.
2.start AutoCAD,then you will not have the "properties" command.
3.disable right click short cut menu,in "options","user preferance" "windows standard behavior" uncheck "short menus in drawing area".
4.close selection cycling and quick property
5.export current profile as *.arg.
6.
to start Autocad with a profile:
In the AutoCAD short cut icon,Properties dialog box, click the Shortcut tab, and in the Target text box enter /p at the end of the name and path of the profile (filename.arg) that you want AutoCAD to use when it starts.
"C:\Program Files\AutoCAD 2000\acad.exe" /p "C:\Program Files\ AutoCAD 2000\FILENAME.arg"
hope it helps.
Hua
Active Contributor
mekohler
Message 10 of 10 (281 Views)
08-27-2012 12:08 PM in reply to: weiwei75412
I did a complete uninstall, and reinstalled Map.  This problem hasn't happened since I reinstalled Map.
Michael Kohler
