AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
3GB switch
11 REPLIES 11
Message 1 of 12
celeste56
1414 Views, 11 Replies
3GB switch
When AutoCad 3d map had the 32 bit system, there was a 3GB switch to allocate more memory for AutoCad.  Does anyone know if there is another switch for the 64 bit system with 8 GB of memory?  I have very large files which freezes AutoCad when it calls for more than 3GB's of memory.
Thank you,
11 REPLIES 11
Message 2 of 12
antoniovinci
in reply to: celeste56
If your Windows is a x64 one, and you have 8 GB Ram, I bet that freeze is NOT a memory issue, sir.
1] unplug your Ethernet cable
2] switch your antivirus off
3] defrag your hard disk
4] ensure you have enough free space in your TEMP partition
5] run Ccleaner many times until you get 0 errors
...and try again: any changes?
Message 3 of 12
celeste56
in reply to: antoniovinci
Thank you for your help. This has been tried, and it didn't change the problem.
Autumn Murr
Sr. Designer
Chevron WCC Projects, SJVBU
9525 Camino Media Drive: Building C #1058
Bakersfield, California 93311
Direct: (661)412-6006
Cell: (661)437-0347
[cid:image001.png@01CEF4C1.A8DFAE60]
Message 4 of 12
parkr4st
What version of map and system specs?
Dave
Message 5 of 12
celeste56
in reply to: parkr4st
2012. Which system spec's are you looking for?
Autumn Murr
Sr. Designer
Cell: (661)437-0347
[cid:image001.png@01CEF4C6.2FDAE660]
Message 6 of 12
parkr4st
Windows Version, cpu, total memory, graphics card, etc
based on my experience
2012 and xp = heartburn
2012 is ok with Win 7 Pro but still isn't happy
2013 & 2014 work only with Win 7
Message 7 of 12
antoniovinci
Between my post and yours I see only 8 minutes, whilst the above 5 steps need (at least) 1 hour of hard IT work...
If you wanna get helped, you outta do exactly what we advise: no room for jokes, sir.
Message 8 of 12
celeste56
Please don't get upset. I let you know it was tried prior to posting the question. This isn't personal.
Autumn Murr
Sr. Designer
Cell: (661)437-0347
[cid:image001.png@01CEF4D1.1CD13D20]
Message 9 of 12
braudpat
Hello from France
So you have a 64 bits PC with 8 Gb Ram and of course 64 bits version of ACAD / MAP / etc ...
I have 2 PCs 64 bits (Win 7 Pro) with 8 Gb Ram
On these PCs I have already seen the "ACAD.exe" 64 bits Task using about up to 5.0 - 6.5 Gb without any problem !
You don't need any special parameter !
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 10 of 12
antoniovinci
in reply to: braudpat
C'est vrai, monsieur!
Moreover, dear Celeste, after you deeply defragged your hard disk, you can set a fixed swapfile as big as 2x Ram.
Doing so, when the physical memory will be filled up, Windows will supply to Autocad a lot of additional virtual space.
Message 11 of 12
celeste56
Dear braudpat,
Please read my comments completely. The hard drive was defragged prior to my message. Your insistence is rude by implying I am lying. If you cannot conduct yourself in a respectful manor, then do not answer my posts.
Autumn Murr
Sr. Designer
Cell: (661)437-0347
[cid:image001.png@01CEF567.F90F5010]
Message 12 of 12
braudpat
Hello
Sorry 1 - My US/English is not my native language so maybe I miss something in your topic !
I am speaking only about the fact that with 64 bits Software on 64 Bits Windows
you don't need to set any parameter to be able to use all/more memory
I don't speak about hard disk, fragmentation, etc ...
Sorry 2 - As Antonio said, I have forgotten something : increase the swap file size !
With 8 Gb memory, my advice will be : 16 Gb to 32 Gb for the swap file size !
Bye, Pat
Patrice BRAUD
”Boost
