AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
3d Face.!
3 REPLIES 3
tugce
3039 Views, 3 Replies
3d Face.!
Hi.!I need a closed polyline parcel,but parcel made in 3d face.How can ı convert 3d face to polyline.?3d face object don't explode.Thanks..!
3 REPLIES 3
in reply to: tugce
FLATTEN will "explode" a 3D face into lines, which you can
then join back into a polyline.
You can also use WMFOUT then WMFIN. After the WMFIN, you
will have a block. Explode it and you will be left with a
closed polyline.
R.K. McSwain
http://rkmcswain.blogspot.com
tugce
in reply to: tugce
Firstly,you can export 3d face objects DGN format and then you can import DGN objects.3d faces will be polyline...But it's imortant choosing 'Import polygons as closed polyline'...
in reply to: tugce
True, if you have MAP. (Yes, I know this is the MAP group...)
The other two methods work with vanilla AutoCAD and MAP.
R.K. McSwain
”Boost
