AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
2012 Map 3D Install Missing dll
2 REPLIES 2
grimline
2411 Views, 2 Replies
I Downloaded, Installed and Reinstalled Map 3D 2012 but it still tells me it can't find dll. See below. I am clueless as to what to do next. Help. TYIA
dll or other file that it needs.
c:\program files\autodesk\autocad map 3d 2012\acmapdwfapi.arx cannot find a dll
.Failed.
AcMapWorkspace.arx Load Failed
AcMapDwfApi.arx Load FailedRegenerating model.
c:\program files\autodesk\autocad map 3d 2012\acmaploader.arx cannot find a dll
c:\program files\autodesk\autocad map 3d 2012\bin\tbexporter.arx cannot find a
AutoCAD menu utilities loaded.
Command: _RIBBON
Command: COMMANDLINE
Autodesk AutoCAD Map 3D 2016
Windows 7 Professional
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
2 REPLIES 2
grimline
in reply to: grimline
Figured it out. The Fail happens when I imported my Profile from Map 2010.
I deleted the Profile and created a new one for Map 2012.
Everything is fine now.
TY
8.00 GB RAM
To be more specific, for me the folder that needed to be added to the support files was:
C:\Program Files\Autodesk\AutoCAD Map 3D 2012\bin\FDO
That is a folder that contains a lot of dll's.  Now I'm not getting any more dll errors.  I'm not positive that is the precise right thing to do, but it seems to work at this point.
”Boost
