I Downloaded, Installed and Reinstalled Map 3D 2012 but it still tells me it can't find dll. See below. I am clueless as to what to do next. Help. TYIA
dll or other file that it needs.
c:\program files\autodesk\autocad map 3d 2012\acmapdwfapi.arx cannot find a dll
.Failed.
AcMapWorkspace.arx Load Failed
AcMapDwfApi.arx Load FailedRegenerating model.
c:\program files\autodesk\autocad map 3d 2012\acmaploader.arx cannot find a dll
c:\program files\autodesk\autocad map 3d 2012\bin\tbexporter.arx cannot find a
AutoCAD menu utilities loaded.
Command: _RIBBON
Command: COMMANDLINE
Solved by grimline. Go to Solution.
Figured it out. The Fail happens when I imported my Profile from Map 2010.
I deleted the Profile and created a new one for Map 2012.
Everything is fine now.
TY
To be more specific, for me the folder that needed to be added to the support files was:
C:\Program Files\Autodesk\AutoCAD Map 3D 2012\bin\FDO
That is a folder that contains a lot of dll's. Now I'm not getting any more dll errors. I'm not positive that is the precise right thing to do, but it seems to work at this point.
