AutoCAD Map 3D General Discussion
Valued Contributor
stevedb
Message 1 of 4 (329 Views)
Accepted Solution
2012, hatch window
329 Views, 3 Replies
03-06-2012 02:43 PM
hello.
In using this new-- to me-- version of map, I've just tried making a hatch, and notice that it no longer calls up the window that it used to call up in the older versions-- 2009 and earlier, for me.
Is there a setting that I can set to ensure that the hatch window comes up?
I rarely use the default type/pattern name and scale settings, and I prefer to select my boundaries, instead of selecting a point within an area.
TYIA.
At least two options to get that in 2011 should be the same in 2012.
First just enter T at the command line after you enter the Hatch command.
Second way is click on the Options  arrow in the ribbon tab Hach Creation as shown in the attached image.
*Expert Elite*
Murph
Message 2 of 4 (327 Views)
Re: 2012, hatch window
03-06-2012 03:05 PM in reply to: stevedb
Murph
Supportting the troops daily.
Valued Contributor
stevedb
Message 3 of 4 (324 Views)
03-06-2012 03:19 PM in reply to: Murph
thank you Murph.
Exactly what I wanted.
Valued Contributor
stevedb
Message 4 of 4 (320 Views)
03-06-2012 04:04 PM in reply to: stevedb
ok, I finally figured out what your screen shot showed.
It appears that the hatch editor not only provides the old window, but a ribbon version also activates..... This is a new thing.... :smileysurprised:
so many choices, and so little time to work through everything.....
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
