AutoCAD Map 3D General Discussion
Active Member
0 Kudos
Post 1 of 14
2.5D Buildings
288 Views, 13 Replies
04-27-2012 12:51 AM
I want to create 2.5D Buildings, like at google maps website.
example
anyone know how to do it?
194 Kudos
Post 2 of 14
Re: 2.5D Buildings
04-27-2012 01:09 AM in reply to: jeffb1910
Select your lines or 2D poly, then Properties and change the THICKNESS value.
If you wanna instead get 3D objects, simply issue _EXTRUDE on closed polylines.
Active Member
0 Kudos
Post 3 of 14
Re: 2.5D Buildings
04-27-2012 09:13 AM in reply to: antoniovinci
I press "connect" and then "Add SHP Connection".
I Chose the 2D shp file, connect it and then add to map.
I have height value and i want to create 2.5D Buildings from my data, like google maps example
what is my next step?
Thanks!
1,210 Kudos
Post 4 of 14
Re: 2.5D Buildings
04-27-2012 09:43 AM in reply to: jeffb1910
in that case you can't use the FDO technology as you need AutoCAD polylines for extrusion.
So use command _MAPIMPORT, after you selected type SHP and the filename don't forget in the next dialog to go to the 3rd tab and mark "use closed polylines for polygons" (not the exact wording).
Then you have polylines and can do what antoniovinci suggested to do.
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 5 of 14
Re: 2.5D Buildings
04-27-2012 11:02 AM in reply to: jeffb1910
i used the mapimport command and its import points instead polygon
1,210 Kudos
Post 6 of 14
Re: 2.5D Buildings
04-27-2012 11:06 AM in reply to: jeffb1910
what version of Map3D do you have?
Are you sure that you selected the correct SHP-file? Because I don't know any option within Map3D that creates points from a polygonal shape!
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 7 of 14
Re: 2.5D Buildings
04-27-2012 11:10 AM in reply to: Alfred.NESWADBA
AutoCAD Map 3D 2013
Active Member
0 Kudos
Post 8 of 14
Re: 2.5D Buildings
04-27-2012 11:13 AM in reply to: jeffb1910
it was my mistake! sorry!
1,210 Kudos
Post 9 of 14
Re: 2.5D Buildings
04-27-2012 11:17 AM in reply to: jeffb1910
Could happen always and to everyone, don't worry!
- alfred -
Alfred NESWADBA
Active Member
0 Kudos
Post 10 of 14
Re: 2.5D Buildings
04-27-2012 11:21 AM in reply to: Alfred.NESWADBA
Now i can see the 2d polygon of buildings.
i have the height value for the polygons.
How i can convert the polygon to 2.5D like google maps?
Thanks!
