AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
2.5D Buildings
13 REPLIES 13
Message 1 of 14
631 Views, 13 Replies
2.5D Buildings
I want to create 2.5D Buildings, like at google maps website.
example
anyone know how to do it?
Tags (1)
13 REPLIES 13
Message 2 of 14
antoniovinci
Select your lines or 2D poly, then Properties and change the THICKNESS value.
If you wanna instead get 3D objects, simply issue _EXTRUDE on closed polylines.
Message 3 of 14
in reply to: antoniovinci
I press "connect" and then "Add SHP Connection".
I Chose the 2D shp file, connect it and then add to map.
I have height value and i want to create 2.5D Buildings from my data, like google maps example
what is my next step?
Thanks!
Message 4 of 14
Alfred.NESWADBA
in that case you can't use the FDO technology as you need AutoCAD polylines for extrusion.
So use command _MAPIMPORT, after you selected type SHP and the filename don't forget in the next dialog to go to the 3rd tab and mark "use closed polylines for polygons" (not the exact wording).
Then you have polylines and can do what antoniovinci suggested to do.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 5 of 14
i used the mapimport command and its import points instead polygon
Message 6 of 14
Alfred.NESWADBA
what version of Map3D do you have?
Are you sure that you selected the correct SHP-file? Because I don't know any option within Map3D that creates points from a polygonal shape!
- alfred -
Alfred NESWADBA
Message 7 of 14
in reply to: Alfred.NESWADBA
AutoCAD Map 3D 2013
Message 8 of 14
it was my mistake! sorry!
Message 9 of 14
Alfred.NESWADBA
Could happen always and to everyone, don't worry!
- alfred -
Alfred NESWADBA
Message 10 of 14
Now i can see the 2d polygon of buildings.
i have the height value for the polygons.
How i can convert the polygon to 2.5D like google maps?
Thanks!
Message 11 of 14
Alfred.NESWADBA
Look to the first answer you got in this thread from antoniovinci, that answers your question
- alfred -
Alfred NESWADBA
Message 12 of 14
Murph_Map
Like this?
http://map3d.wordpress.com/2009/08/17/putting-3d-back-in-map3d/
Murph
Supporting the troops daily.
Message 13 of 14
antoniovinci
in reply to: Murph_Map
Murph wrote:
Like this?
Exactly, but you wrote (* 100 &”Aged 1 year”@001) with unnecessary signs like & and "
You can simplify the expression there, with the following syntax:
(operator :fieldname@shapename factor)
In your case, it would sound like this: (* :aged1year@001 100)
Message 14 of 14
Murph_Map
@antoniovinci wrote:
@Anonymous wrote:
Like this?
I think I tried that and with the "Inters String, Real' in recent versions mess up it didn't work or something.  ???
Murph
”Boost
