AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
To copy Style rules to a different Shapefile
2 REPLIES 2
gperego
422 Views, 2 Replies
Hi all,
I am asking how to copy a style to a different Shapefile.
I created a complex style for a shapefile, connected with FDO.
Thematic rules, labels and so on.
Now, I want to use the same style for an other Shapefile, that has the same structure.
If I save a .layer, this contains also the connection to the original Shapefile.
How can i do it?
Many thanks!
Giovanni
2 REPLIES 2
thepworth
in reply to: gperego
the .layer file is in xml - you might "play" with either notepad or "XML Notepad" to edit and find/replace the connection name and pathing directly using either editor.
Anyone else know of a way to do it?
gperego
in reply to: thepworth
Many thanks!
Yes, this can be a solution.
Some one else?
Regards
Giovanni
”Boost
