I'm overlaying excavated trenches onto an old OS map and on the screen all is well. In print preview, all is well, when i plot (either to HP PageWide Color MFP E77650 or pdf), the raster image moves and the vector and raster are misaligned. Does anyone have a solution to this? I've been through this forum and others and found other people having the same issue, but either with no solution or solutions that haven't worked for me.
I have AutoCAD map 3D 2018 working on Windows 10, Intel Core i7-7700, 32GB of RAM - with all hotfixes up to date (as far as i know).
I have tried attaching the raster image with _imageattach and with _mapiinsert and the result is the same in both.
I have tried plotting to Adobe pdf and to AutoCADs own dwg to pdf and the result is the same in both.
I've made some fake trenches to test the movement and to see if the gps file was the problem, but the downloaded data and made up data reacts in the same way.
I've tried using different types of raster - .tif and .png and both react in the same way.
I've tried setting the co-ordinate system, and removing the assigned co-ordinate system and the result is the same.
As a final desperate attempt, I locked the layer with the raster image in it and it made no difference.
I've attached a screen capture of what the image should look like and a pdf of what happens when i plot. This doesn't happen with every drawing or with every user but if anyone can help i would be VERY grateful.
Maybe it would be better to attach an example of your raster and vector here?
Fair point 🙂
dwg attached, along with .tif raster
As it is, without doing any funn y business, I wasn't able to reproduce the misalignment you allude to in your opening post. However I did notice something that may, or may not, contribute to your situation. Your drawing titled Test to upload.dwg has some line work drawn in modelspace and some in paperspace. If you zoom in and out of your viewport the line work in modelspace will scale while the lines drawn in paperspace will remain status quo.
For clarity, I have changed some black lines to red and have drawn a blue revision cloud.
Chicagolooper
That's what happens when I rush a test dwg. Typical. To be honest, ignore the red lines as I added those just to see what happened when I converted to pdf and sent the drawing to our plotter. As you can see in the screen cap, the black lines over the field boundaries (in model space) etc are misaligned as well as the trenches, hence the assumption that it is the raster that moves, not the vector data.
I couldn't find anything odd in the .dwg. I'd purged it and audited it just in case. The error hasn't re-appeared today for me or any other user, other than in this .dwg.
Hope that clarifies the model/paper space thing.
I don't know about that. Are you saying the coordinate system is causing your image to jump around? BTW, I can was able to TRANSFORM your drawing into LL84 zone 30. The result is above.
Chicagolooper
No, I think you've misunderstood. I'm not concerned about the co-ordinate system. I listed it as something I had tried in case it was causing a problem, but i found out that it isn't. I'll try and explain again:
In my .dwg, I'm happy with the location of my raster and vector data. It's located where i need it and all is well (ignore the stuff accidentally in paper space). When I convert to pdf or plot to an actual printer, the raster and vector data becomes misaligned. It's a visual issue. I know that my lines and maps are in the right place in the dwg, it's just that when i need to send non autocad files to other people, the information no longer looks correct.
I hope that makes sense.
Cheers
What is your image referenced against? Did you verify whether your image can read its projection, it won't project correctly is the projection is read incorrectly or it can't be read at all.
What is coordinate system you have assigned to modelspace?
How did you bring in your image? Data connection? Or MAPIINSERT? Another way?
Chicagolooper
Revisited this issue using the OP's original image. Unable to replicate the OP's issue. There is no movement in either the image itself or the line work as described by the OP. As shown below, the OP's uploaded image, the line work and Bing Maps are all in harmony.
Are you able to upload your drawing that contains your line work and your image?
BTW, if you are inserting a PDF into your dwg, I would recommend you convert your PDF into a jpeg, tiff, png or something other raster format, then try again. Using a PDF as a background image is overrated, way over. Avoid using use PDF.
Chicagolooper
