Project Basejump is a free technology preview on Autodesk Labs:
http://labs.autodesk.com/utilities/basejump/
You can try inserting from Bing as a base layer in your AutoCAD Map 3D drawings. Please try it and reply to this thread.
Is it compatible with any version other than 2013? I'd like to try it out, but I only have 2010...
Norm
We have been patiently waiting for this technology for a while and look forward to providing feedback on this new feature.
One question:
The Availability states: “This technology preview will operate until June 30, 2012.” Is that correct, that it will expire in two months?
C
Is there any sort of help associated with this? I'm constantly seeing the error:
There was a problem adding data to Map.
I've tried a bunch of different coordinate systems and locations. It starts Adding Layers... and then throws the above error. I'm using Map 3D 2013 x64. Thanks.
Not seeing the connection issue here.
Civil 3D 2013 x64 connects to all three Bing Servcies without issue.
Thank you!!!
I have the same issue and disabled my firewall to test if that was the issue, and was able to connect succesfully with the firewall disabled.
I am using Zone Alarm 10.1.065.000.
I don't want to run my computer on the internet with out a firewall though. 😞
I have sent an email to autodesk lab requesting info on which program or port I need to allow internet access in order to get it to work.
I checked and all the autodesk programs and components have access to the internet.
Hi Norm,
I'm sorry, this technology preview only opperates wtih AutoCAD Map 3D 2013 and AutoCAD Civil 3D 2013.
Best regards,
Hanspeter
You are right, our agreement with Microsoft is that we will have this technology preview on Labs until June 30. Your feedback determines what happens next.
Best regards,
Hanspeter
Hi Andrew,
Basejump Technology Preview connects to Bing Maps Services using https and http. Please make sure that Map 3D Client (acad.exe) is able to connect to the internet through your firewall.
Best regards, Hanspeter
That's a pretty good thing. I can see the power we could get out of this.
However, the main problem I see so far is the quality of the Bing image in Switzerland: while the Bing roads are quite precise, the aerial view is somehow translated, which isn't useful when one's working.
What you see in that pricture (from foreground to background):
1. Water network (red, blue and yellow pipes, valves and labels) comes from the Oracle database
2. the "white" roads and the buildings come from the database
3. the "gray" roads were added by the Bing connection
4. the Bing raster.
1 and 2 use the coordinates "CH1903/GBS.LV03-M".
3 and 4 use the coordinates "WGS84.PseudoMercator".
What we can notice:
On the road going from bottom-right to top-left, the layers 1, 2 and 3 are quite good as it's a main road; the raster is translated...
On the road going from bottom-right to top-middle, the layers 1, 2 are good (that's normal, as the network is based on these roads); the layer 3 is no more that precise on secondary roads and the raster is translated...
Hi all,
I tested the the new brave Basejump project Friday 4th of may.
It is wonderful, and all works well also with italian coordinate systems.
I wrote about it in my italian Blog:
http://www.bimacademy.it/gis/2012/05/usa-le-mappe-di-bing-in-autocad-map-3d-e-civil-3d/
(you can choose Google translate to read it in english language)
The only problem is the same of all WMS connections.
If you use a Proxy, like many of our customers, you can’t connect to Bing.
I used an other line, free from the Proxy, but I know tha many people will ask me how to solve this problem, to use beautiful Bing maps in their projects
I already applied the solution of the Knwledge Base:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11794193&linkID=9240857
But, unfortunately, i need to introduce also name and password.
I tried also to cìreate system variable all_proxy, like:
nnn.nnnnnn.nnn:8080:name.surname:password
But the connection doesn’t work.
If you can find any workaround, it will be vey useful!
Many thanks
regards
Giovanni (GimmiGIS) Perego from Italy
I wasn't able to test in AutoCAD Map3D 2012 I will have to wait until I can install a 2013
I was wondering about Bing Maps License. Do we need to purchase a separate Microsoft Bing Enterprise License for using Basejump?
No, there is no need for a separate Bing Maps License to use the timely limited Basejump Technology Preview.
Thanks for the preview. It's simple and works quickly.
I notice there is only an Add to Map option. Is there no way to clip the map, short of creating your own coordinate system? That works, but it takes a while and I don't think most users know how to do that. It would be easier to just have a clipping option.
When you select the map it is listed as ACMAPGISGRIDSURFACEENTITY. That makes me think there may be a topography element to this. Is there a way to access that?
Very nice. Simple to install and use, I can see a great benefit for maps that i prepare.
Plus, you can actually print with Bing in the background! Any way to add that feature to AIMS?
Hi Tim,
On Add to Map, the Bing map is transformed into the coordinate system of your current Map project. The map is therefore clipped to the valid extens of the coordinate system. If the Bing map is the first layer beeing added, the Map project gets the default coordinate system of Bing Maps which is Pseudo Mercator and covers the entire world.
Regarding "topography element", do you ask if the entity contains elevation data? Not every ACMAPGISGRIDSURFACEENTITY’s image has elevation data. Currently, the Bing map entity does not have elevation data.
Works great. But in several rotated viewports the image remains extremely pixelated.
Some of the rotated viewports look nice and the image refreshes with each zoom.
Two of them (same scale and everything) will not refresh and you cannot see anything except huge pixels.
Anything I can try?
