AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
map to DWG block trouble
0 REPLIES 0
Message 1 of 1
226 Views, 0 Replies
I themed a map and used blocks (dwg's) that i loaded in the style editor for symbols (valves, manholes, etc).  When saving my map back to a dwg, i followed the instruction: created a dwt with the blocks loaded in it, the block names remain identical as do the layer names.  but in the the new dwg the blocks are named "symbol1_1, "symbol1_0"....  inexplicably one layer gets it right 1 out of 5 times.  In the map i save whatever changes i make to the spatial layer, i have the desired block on the desired layer in the template but still block "vlv" in the map becomes a block named "symbol1_*", one of my blocks with an "M" in it becomes several polylines and MText in the dwg.  what am i missing?
0 REPLIES 0
”Boost
