AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Instability in Map 3D 2012 with Oracle FDO provider
2 REPLIES 2
tmblackflag
555 Views, 2 Replies
Is anyone using this provider without issue? I kept getting random errors while editing features like:
- failed to save edit set
 -feature source is disconnected
- failed to describe class
- item "layer name" not found in collection
- SchemaName: LayerName (304). Rev #<1>
In every instance I am absolutely connected to Oracle. Editing features typically works the first time I setup the drawing's connection. However after saving and reopening the drawing the issues sometimes, not always surface.
This works 100% stable in Map 3D 2010 but I unfortunately need the ENHANCED styling that Map 2012 provides.
My setup:
Windows 7 64bit
4gb ram
Oracle 11gR1 64bit client
Map 3d 2012 64bit
2 REPLIES 2
gluckett
in reply to: tmblackflag
Yes, you are not alone.  This occurs in 2013 (Map 3D and AIMS) too.
I have been testing Autodesk FDO for Oracle and SL-KING FDO for Oracle and found that the Autodesk FDO for Oracle has some significant instabilities, especially over 100 users.  I've switched to SL-KING FDO but there are some limitations with Themeing etc.
The Autodesk FDO for Oracle definitely needs some tweaking, if not some serious re-work for both Autodesk Map 3D 2012 and 2013 as well as Autodesk Infrastructure Map Server 2012 and 2013.
tmblackflag
thank you Gordon.
I recently opened a ticket with Autodesk. They said my errors were linked to a change request that is fixed but not due out until their next patch which they have no date for.
They advised me that these issues are fixed in 2013 so I upgraded and have had good results so far. However my user group is only about 7 so I  would probably not encounter some of the issues you are having.
”Boost
