AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Fatal Error reading 0x0020 Exception at 72e5b578h on Close
1 REPLY 1
1343 Views, 1 Reply
We are getting a fatal error when closing Map 3d 2012 when we close AutoCAD MAP 3d 2012.
Everything saves, but it is an incovienence to the client.
Has anyone seen this before and is there either a way to fix the error, or to turn off errors on close?
1 REPLY 1
we get a less detailed message when closing ACMap 2012 (at least when closing it using the icon on the main application window) - "application doesn't work anymore. a problem prevented the program ....". If I remember correctly it is not an Map issue but a general AC issue (for release 2012) - you might want to check AC disc list as well.
What you could try (I haven't) is to close the application via AC Map main menu > close application.
Good luck, Rob
”Boost
