AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export point coordinates as .csv
4 REPLIES 4
archaeoman
31998 Views, 4 Replies
Greetings all,
My quick question id for an alternative way of exporting a cluster of points as .shp files and then manipulating the .dbf file in order to create an excel/csv file.
Is there another way of exporting my data as .csv or excel from Map3D?
Thanks in advance
4 REPLIES 4
parkr4st
in reply to: archaeoman
if your .shp is in a map, open the data table and select the records to export, options export to .csv
hence_the_name
your approach exporting as SHP is probably the quickest but Map has a feature to create  CVS files - further details in Map help - "Running a Query in Report Mode":
http://docs.autodesk.com/MAP/2013/ENU/filesMAPUSE/GUID-82F678B9-EF66-4E42-B281-527E339E3BD8.htm
Basically you need to attach you drawing with the points,
create a query
create a report
execute query
Report can include ac-object properties (coordinates etc.) and map object data as well.
Good luck,
Rob
http://raumpatrouille3d.blogspot.ch/
antoniovinci
Gentlemen, the OP has no shapefiles: he just wanna avoid to create them.
He has a bunch of points, from which extracting the XYZ coords to an external .CSV, period.
There are several ways to accomplish that, either internal (command _DATAEXTRACTION) and external like this one.
Exactly what I needed. Thank you sir!
”Boost
