AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autocad Map 3d labels not printing
4 REPLIES 4
jcrisafulli
645 Views, 4 Replies
Not all labels print.
I converted text to an FDO. Not printing
I then converted the FDO to an SDF. Still not printing.
What next?
Tags (1)
4 REPLIES 4
Murph_Map
in reply to: jcrisafulli
The default to print FDO labels is set to 2000 (?) You can edit the registry to increase that number. However I don't know what key it is off hand and with the redesign of Autodesk support site I failed to find the link to the white paper on it. Sorry.
Murph
Supporting the troops daily.
Alfred.NESWADBA
in reply to: Murph_Map
there it is: >>>MAX_LABLES in Map3D<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
braudpat
Hello from France
Welcome to the Autodesk/AutoCAD Forums !
It's a very OLD limitation of MAP (or CIVIL) FDO Label Engine !
... Same limitation with MAP 2008/2009 ...
I don't understand why Autodesk hasn't increased this value or let a New MAP System Variable controlling the maximum number of FDO Labels !?
The register key "R1x.y" for each MAP is different :
MAP 2010 : R18.0
MAP 2011 : R18.1
MAP 2012 : R18.2
MAP 2013 : R19.0
MAP 2014 : R19.1
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Alfred.NESWADBA
in reply to: braudpat
MAP 2015 : R20.0
- alfred -
Alfred NESWADBA
”Boost
