AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
What happened to ade_expreval function?
1 REPLY 1
rnicz
616 Views, 1 Reply
Hello!
Sometimes I use ade_expreval function and I noticed that in AutoCAD Map 2013 it does not work as in previous versions. It simply accepts as many arguments as you pass to it and it always returns nil.
Command: (ade_expreval en ".CENTER" "point" "ABC")
nil
Command: (ade_expreval en ".CENTER")
nil
Command: (ade_expreval en)
nil
Command: (ade_expreval)
nil
Is it expected bahaviour?
Best regards
RN
Tags (1)
1 REPLY 1
mapaquin
in reply to: rnicz
I tested the following in AutoCAD Map 3D 2013 and it works:
(setq myobject (car (entsel "Select an object:")))
(setq value (ade_expreval myobject ".center" "point"))
Now what I need to know is the equivalent of "ade_expreval" in ObjectARX (.Net)?
Marc
”Boost
