AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
VB.NET Map Query
2 REPLIES 2
ced_abitat
851 Views, 2 Replies
VB.NET Map Query
Hi All,
  I have a problem with VB.NET and Map using ActiveX interface.
I have an error when I try to add a new condition to QueryBranch
Ex
Dim objQB As AutocadMAP.QueryBranch = objQuery.QueryBranch
Dim objPCond As Object = objQB.Add(EClassId.kQueryBranch, EJoinOperator.kOperatorAnd)
The same code in VB6 work fine!!!
Can you help me?
Regards
Matteo
2 REPLIES 2
in reply to: ced_abitat
Hi Matteo,
Check if the following approach resolves this issue ?
<code_begin>
Public Function TestDefQuery()
Dim mapApi As Autodesk.Gis.Map.MapApplication
mapApi = MAP.HostMapApplicationServices.Application
Dim project As PROJECT.ProjectModel
project = mapApi.ActiveProject
'create location condition
Dim JointOp As New MAPCONSTANTS.JoinOperator()
Dim locationType As New MAPCONSTANTS.LocationType()
'Dim qryCondition As MAPQUERY.LocationCondition = New MAPQUERY.LocationCondition(JointOp.OperatorAnd, locationType.LocationInside)
Dim qryCondition As MAPQUERY.LocationCondition = New MAPQUERY.LocationCondition(JointOp.OperatorAnd)
Dim allBdry As MAPQUERY.AllBoundary
allBdry = maputil.NewAllBoundary()
qryCondition.Boundary = allBdry
'create branch
Dim qryBranch As New MAPQUERY.QueryBranch(JointOp.OperatorAnd)
qryBranch.AppendOperand(qryCondition)
End Function
<code_end>
Partha Sarkar
Autodesk Developer Network
dohenry
I just tried out this code and it works well.
However I was getting an error in the following line
I changed it to
allBdry = project.MapUtility.NewAllBoundary
and it resolve the error.
Donagh
”Boost
