AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
URGENT - HELP - PROBLEM WITH COORDINATE SYSTEMS - CSD FILES
0 REPLIES 0
Message 1 of 1
vasco_rou
448 Views, 0 Replies
Hello
I'm having problem to actualize CSD files after creating and defining new systems corrdenadas as attached files. When I try to use the API CSUPDATE an error is generated and the process is not complete.
I also have begotten file manually processing between systems created but when I try to generate a KML file gets published elsewhere completely wrong despite being in geographical and flat corrdenadas correct at DWG.
We also tried to perform the update using CSUPADTE but in this case an internal error and generated API. See attached log file.
Note: The problem is related category in Brazil created the category Brasil_Acad is an copy of the original MAP own
thank you
0 REPLIES 0
”Boost
