I have a form that all the object data gets imported into when I select a parcel. I want to be able to edit the data and overwrite the object data in my drawing.
Using the code below when I hit the button and select the parcel I want to overwrite the data to, it attaches a duplicate table with the same name to the entity and all the data is empty except for the owners name. What do I need to change to make it just overwrite the existing table without creating a duplicate one.
Private Sub updateOD_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles updateOD.Click
Dim id As ObjectId '= myid
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Dim odTable As Autodesk.Gis.Map.ObjectData.Table
Dim odTables As Autodesk.Gis.Map.ObjectData.Tables
odTables = HostMapApplicationServices.Application.ActiveProject.ODTables
Try
Dim ed As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Using docloc As DocumentLock = doc.LockDocument
Dim prompt_result As PromptEntityResult = ed.GetEntity(vbCrLf + "Select the object...")
id = prompt_result.ObjectId
Dim dbObj As DBObject = trans.GetObject(id, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
'' Presuming OD Table "MyTestODTable" exist in the DWG file
odTable = odTables.Item("All_Parcels")
Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForRead, False)
Dim odRecord As ObjectData.Record = odrecords.Item(0)
odRecord = Autodesk.Gis.Map.ObjectData.Record.Create()
odTable.InitRecord(odRecord)
Dim mapVal As Autodesk.Gis.Map.Utilities.MapValue
'' Add a Record and assign a value to it
mapVal = odRecord(3)
mapVal.Assign(OwnerName.Text)
' dbObj should be opened for Write, otherwise
odTable.AddRecord(odRecord, dbObj)
odRecord.Dispose()
odrecords.Dispose()
trans.Commit()
End Using
Catch exc As Autodesk.Gis.Map.MapException
MsgBox("Error : " + exc.Message.ToString())
End Try
End Sub
End Class
Solved by tdunn3. Go to Solution.
Your code actually does is no matter whether there is already a record of the ODTable attached the entity or not, it always create a new record and attach it to the entity, thus duplicated. In fact, if you run your code multiple time, there would be more records of the same ODTable to be attached to the entity.
Yo need to do is, first, check if the entity already has the record attached. If yes, update the record, if not, create a new record, attach it to the entity.
Something like (not tested):
using (Records records=theTable.GetObjectTableRecords(0, objId,OpenMode.OpenForWrite,true))
Record rd=null;
bool attach=false;
If (records.Count==0)
rd=Record.Create();
theTable.InitRecord(rd);
attach=true;
else
rd=records[0]
//Set record's field value here
for (int i=0; i<rd.Count; i++)
MapValue val=rd[i];
//Assign value to each field as needed
val.Assign(.....);
if (attach) theTable.AddRecord(rd, objId);
By the way, you do not need to start a transaction and open an DBObject/Entity. ObjectId obtained from Editor.getEntity() is enough. The ObjectData API handles Transaction internally as needed.
Norman Yuan
Thanks for your help! Made some changes but it still duplicates the table instead of updating the existing one. I really do not need to check if the record exists because I am populating the form text fields with OD from the entity I want to update.
If I take the transaction out and replace odTable.AddRecord(odRecord, dbObj) with odTable.AddRecord(odRecord, id) it throws an error. I just starting to learn vb.net and doing a lot of cutting and pasting from snippets of other code I find on the net and learning as I go.
Dim id As ObjectId
' Dim tableName As String
Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForWrite, True)
Dim odRecord As ObjectData.Record = odrecords(0)
mapVal = odRecord(2)
mapVal.Assign(CntyN.Text)
mapVal = odRecord(6)
mapVal.Assign(Sec.Text)
mapVal = odRecord(7)
mapVal.Assign(Town.Text)
mapVal = odRecord(8)
mapVal.Assign(Range.Text)
mapVal = odRecord(11)
mapVal.Assign(Book.Text)
mapVal = odRecord(12)
mapVal.Assign(Page.Text)
mapVal = odRecord(13)
mapVal.Assign(Desc.Text)
End Using
End Sub
figured it out..replaced
with
odrecords.UpdateRecord(odRecord)
and now I can take out the transaction without an error
Would you please mark the thread as solution by clicking "Accept as Solution" button? This helps everyone find answers more quickly!
Here is what I used to finally get it to work
Dim odrecords As ObjectData.Records = odTable.GetObjectTableRecords(Convert.ToUInt32(0), idEntity, Constants.OpenMode.OpenForWrite, True)
mapVal = odRecord(1)
mapVal.Assign(TractID.Text)
mapVal.Assign(StrConv(OwnerName.Text, VbStrConv.Uppercase))
End Using
