AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
trouble with C# and CAO GetLinks
0 REPLIES 0
Message 1 of 1
masa10789
546 Views, 0 Replies
Does anyone have any small snippets of code they can post as an example of how to use GetLinks or GetLinksBySQLCond? This seems to be a problem with many others too. I referred to the CAOText.dvb example from SDK but I can not get it to work when I write it in C#. Here is what I have and I can not get it to work. I am attempting to get the links from a user selected AutoCAD object, after the user selects the linktemplate from a list box. The problem is at the GetLinks method (last line of code). I have tried passing in different types of objIDs such as array of longs, array of ObjectIDs and still no luck. Ahy help would be appreciated, thanks.
CAO.DbConnect dbConnect = new CAO.DbConnect();
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
//linktemplate object retrieved from user selected menu
CAO.LinkTemplate objLinkTemplate = dbConnect.GetLinkTemplates(doc.AcadDocument).Item(this.lbLinkList.SelectedItem.ToString());
PromptSelectionResult acssPrompt = doc.Editor.GetSelection();
if (acssPrompt.Status == PromptStatus.OK)
 SelectionSet acSSet = acssPrompt.Value
 long[] objIDs = new long[acSSet.Count];
 int i = 0;
 foreach (SelectedObject acSSobj in acSSet)
  objIDs[i] = (long)acSSobj.ObjectId.OldIdPtr;
  i += 1;
 int linkTypes = (int)CAO.LinkType.kEntityLinkType;
 CAO.Links linkSel = dbConnect.GetLinks(objLinkTemplate, objIDs, linkTypes, doc.AcadDocument);
0 REPLIES 0
”Boost
