AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Start/End Node
2 REPLIES 2
383 Views, 2 Replies
Start/End Node
Hello!
Can anybody help me with a start/end node SQL query for a soft-split line?
Gabi
2 REPLIES 2
What help do you need?
I'm trying to make a query that will give me the slope of a pipe.
The ground elevation of the pipe ends are stored as attributes in the pipe's start/end nodes.
I made a query that works for a continious line, but if i need to make it work for a soft-splited line also.
select to_char((100*(
(select ((select Z from WW_POINT
            where FID = (select FID_TO from WW_CONN
                           where FLOW = 2 and FID_FROM = (select FID from WW_LINE
                                                            where FID_ATTR =(select FID from WW_PIPE
        where FID = {FID}))
                         union all
                         select FID_FROM from WW_CONN
                           where FLOW = 1 and FID_TO = (select FID from WW_LINE
                                                          where FID_ATTR = (select FID from WW_PIPE
        where FID = {FID}))))
(select H_US from WW_PIPE where FID = {FID})) from dual)
                           where FLOW = 1 and FID_FROM = (select FID from WW_LINE
        where FID = {FID}))
                         union all
                           where FLOW = 2 and FID_TO = (select FID from WW_LINE
(select H_DS from WW_PIPE where FID = {FID})) from dual)
)/(SELECT SUM(length)
FROM WW_LINE WHERE FID_ATTR = {FID})),'9990.999') from dual
”Boost
