AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Slows down if
0 REPLIES 0
Message 1 of 1
437 Views, 0 Replies
Slows down if
Hi everyone. I have a problem working with Autocad Mapd 3d 2012 Enterprise.
The problem is i have a dwg with autocad objects such as polyline, different blockreference, circles etc. the size of the drawing is about 12Mb, let's name it "test.dwg". I've created an industry model, filled it with about a 800 000 object and draw them to my test.dwg after that i'm trying to delete a mapfeature object that has been drawn from the industry model, but Autocad Map slows down very hard i've been waiting for about 5 minutes for the object delete. When i draw mapfeature objects to an empty dwg file, and work with them (edit, delete, create) everything works fine.
So the question is why Autocad Map slows down when there are autocad objects (polyline, circle etc.) and mapfeature objects in one dwg.
Thanks.
0 REPLIES 0
”Boost
