Hi there
The problem is as follows:
I have several polilinhas (street axes) as a single line.
Each line has an associated table data.
I have to segment (mapclean) each line by inserting a sequential code for each segment.
See example sent em Annex
Is there any way with visual lisp, vba for this procedure?
Thank you
I don't think there is a direct way to do that, but, you can iterate each polyline, and select by fence filtering by text on each polyline segment, that will find the text, now you have to create an indexed structure like (handle,segment#, text), this structure could be a list or something else, my preference goes to an external database so the data will be permanent. Other approach could be a topology, but require more effort and some modifications to the base drawing.
Gaston Nunez
Hello
+1 with gaston
With MAPCLEAN & CutAtIntersection, you will keep the original Object Datas on each New generated Plines ...
But how do you number the NEW Plines ?
- From North to South
- From OLD Vertex 1 to OLD Vertex N
- etc ...
I imagine you need a very specific Lisp/Vlisp routine using ADE MAP functions ...
If you want to break manually ONE Pline without loosing Object Data, please use the MAPBRK routine here :
http://forums.autodesk.com/t5/autocad-map-3d-general/break-polyline-with-object-data/td-p/1175705
PS: in your DWG, you have ONE Line (numbered 1) and many Plines ... Why ?
Patrice BRAUD
