Where are the docs in the Map 3d SDK?, I downloaded 32 and 64 bits version and none of them has docs, just an empty folder.
Gaston Nunez
HI Gaston,
look at this page (bottom):
http://knowledge.autodesk.com/support/autocad-map-3d/getting-started/caas/CloudHelp/cloudhelp/ENU/1231...
Rob
Hi, we have looked through all the links on that page and we found that one link no more exists http://wikihelp.autodesk.com/AutoCAD_Map_3D/enu/2013. On the error page we read that the content should be migrated. But where? There is no link specified for Map. The Wiki was a useful source of API information.
Thanks, but there are no Map 2015 docs there, and the 2014 docs are broken as refers to docs that doesn't exists like this: sdk.arx.net.chm. Also what happened to the wikihelp?
Gaston Nunez
