Hi!
Is there a command or lisp to randomly insert certain blocks (eg. trees) into polyline defined area ? So I select some area defined with polyline and then I want to insert into that area randomly lots of tree blocks (or whatever blocks).
Tried to google but didn't find anything useful.
Any ideas ?
M.
I did something like that with the following principle steps:
HTH, - alfred -
1. Insert one block
2. Use array to multiply the entire area
3. Use MAPCLEAN.Select objects / Duplicates / Desired minimum distance
4. Use MAPTRIM. Select Boundary/Select Objects/Trim Outside Boundary
