AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Puging a block
1 REPLY 1
224 Views, 1 Reply
Puging a block
Hi, i am facing a problem while purging blocks. i want to purge a perticular block through vba. i could able to use only purgeall command from vba. how can i giva an option to select a block name which has to be purged.
If any one is havig idea in this, please tell me.
Thanks & Regards
Suresh.
1 REPLY 1
You can search the block reference and block by
name and delete them.
'This will delete block reference
For i = 0 To ThisDrawing.ModelSpace.Count -
1
 Set ent =
ThisDrawing.ModelSpace.Item(i)
If ent.ObjectName = "AcDbBlockReference"
Then
 Set blockRef = ent
 If
bref.Name = "Your BlockRefenceName" Then
    blockRef .Delete
    Exit For
 End If
End If
'This will delete the block
For i = ThisDrawing.Blocks.Count - 1 To 0 Step
-1
Set block = ThisDrawing.Blocks.Item(i)
if block.Name = "YourBlockName"
then
 block.Delete
 Exit For
End If
Next
Gabriel
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
If any one
Thanks & Regards
Suresh.
”Boost
