AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Problem with reading ObjectData via AcDbDatabase
1 REPLY 1
hokrm
447 Views, 1 Reply
Hi all
I have Drawing (Drawing 1.dwg) with some entities and these entities has attached ObjectData. When i open new (empty) dwg file and run my code so i don't get AcMapODTable object. I need to read Column Name of ObjectData, but method pODCont->GetODTable(pODTable, record.ODTableName() return kErrObjectNotFound. I don't know how Can i get Column Name when i open my Dwg files via AcDbDatabase.
thank you all for advice Milan.
AcDbDatabase* pDatabase = new AcDbDatabase(Adesk::kFalse);
if(pDatabase->readDwgFile(L"c:\\dwgTest\\Drawing1.dwg", _SH_DENYNO)!=Acad::eOk) {
m_strErr.Format(L"I can't open the file: c:\\dwgTest\\Drawing1.dwg !");
acedPrompt(m_strErr);
Acad::ErrorStatus es;
AcDbBlockTable* pBlockTable = NULL;
AcDbBlockTableRecord* pBlockTableRecord = NULL;
es = pDatabase->getSymbolTable(pBlockTable, AcDb::kForRead);
es = pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForRead);
es = pBlockTable->close();
AcDbBlockTableRecordIterator *pIterator = NULL;
es = pBlockTableRecord->newIterator(pIterator);
for(pIterator->start(); !pIterator->done(); pIterator->step()) {
AcMap::EErrCode ec;
Adesk::Boolean AdeskBoolean;
AcMapSession *mapApi = NULL;
cMapProject *pProj = NULL;
AcMapODContainer *pODCont = NULL;
AcMapODTable *pODTable = NULL;
mapApi = AcMapGetSession();
AdeskBool = mapApi->GetProject(pProj);
AdeskBool = pProj->GetODContainer(pODCont);
AcDbObjectId eId;
AcMapODRecordIterator* pTableIterator = NULL;
ec = pODCont->GetObjectODRecordIterator(pTableIterator);
es = pIterator->getEntityId(eId);
ec = pTableIterator->Init(eId, AcMap::kOpenForRead, Adesk::kFalse);
for(; pTableIterator->IsDone() == Adesk::kFalse; pTableIterator->Next()) {
AcMapODTableRecord record;
ec = pTableIterator->GetRecord(record);
ec = pODCont->GetODTable(pODTable, record.ODTableName());
if(ec == AcMap::kOk) {
AcMapODTableDefinition TabDef;
AcMapODColumnDefinition ColDef;
TabDef = pODTable->Definition();
for(int i = 0; i<TabDef.Count(); i++) {
TabDef.GetColumn(ColDef, i);
CString ColumnName = ColDef.Name();
delete pODTable;
delete pTableIterator;
delete pIteretator;
pBlockTableRecord->Close();
delete pDatabase; Edited by: hokrm on Jun 15, 2009 8:47 AM
1 REPLY 1
in reply to: hokrm
Did you ever find a solution to this? I'm trying to do the same thing.
Jamie
”Boost
