AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
PointMonitor on Feature Objects
6 REPLIES 6
kob4lt
1221 Views, 6 Replies
Is it posible to implement PointMonitor to show some info about Feature Objects linked with FDO?
6 REPLIES 6
norman.yuan
in reply to: kob4lt
Yes, it is definitely possible. Just as you can show regular Acad entity info with PointMonitor event hanlder (PointMonitorEventArgs.AppendToolTip()), you can use Autodesk.Gis.Map.Platform.Interop.AcMapFeatureEntityService class to obtain feature object information from an Acad entity's ObjectId.
Here is an runable example:
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.Gis.Map.Platform.Interop;
using OSGeo.MapGuide;
[assembly: CommandClass(typeof(MapFeatureTest.MyCommands))]
namespace MapFeatureTest
    public class MyCommands
        private Document _dwg = null;
        private bool _msgOn = false;
        [CommandMethod("MapMsgOn")]
        public void MsgOn()
            if (_dwg == null)
                _dwg = Application.DocumentManager.MdiActiveDocument;
                _dwg.Editor.PointMonitor +=
                    new PointMonitorEventHandler(Editor_PointMonitor);
            _msgOn = true;
        [CommandMethod("MapMsgOff")]
        public void MsgOff()
            if (_dwg == null)
                return;
            else
                _dwg.Editor.PointMonitor -= Editor_PointMonitor;
            _msgOn = false;
        private void Editor_PointMonitor(
            object sender, PointMonitorEventArgs e)
            if (_dwg == null) return;
            if (!_msgOn) return;
            Editor ed = _dwg.Editor;
            FullSubentityPath[] paths = e.Context.GetPickedEntities();
            if (paths.Length > 0)
                ObjectId[] ids=paths[0].GetObjectIds();
                if (ids.Length > 0)
                    ObjectId selId = ids[ids.Length - 1];
                    string tipText = GetToolTip(selId);
                    e.AppendToolTipText(tipText);
        private string GetToolTip(ObjectId selId)
            StringBuilder str = new StringBuilder();
            str.Append("ObjectId: " + selId.ToString() + "\n");
            str.Append("DxfName: " + selId.ObjectClass.DxfName + "\n");
            if (selId.ObjectClass.DxfName.ToUpper() == "MAPBULKFEATURE")
                str.Append("Feature: " +
                    AcMapFeatureEntityService.
                    GetLayer(selId).FeatureClassName + "\n");
            return str.ToString();
 "Netload" this code into AutoCAD and enter "MapMsgOn" command. Then if you move cursor over an Acad entity or a map feature entity in Acad editor and wait a moment, a tooltip will show.
Norman Yuan
Drive CAD With Code
kob4lt
in reply to: norman.yuan
I load SDF file with few Feature objects
I dont know why but I am getting this error
Error on Feature object
norman.yuan
in reply to: kob4lt
I have no idea. In my test, I added feature objects from a shape file. It works well.
See this vidoe clip
Norman Yuan
Drive CAD With Code
matus.brlit
in reply to: kob4lt
i don't know if this helps, but i was also getting this error and it stopped when i turned off the rollover tooltips
kob4lt
in reply to: matus.brlit
That's it! It worked!
br-br-br
Sorry, but i have the same question.
We can see feature object information, can we read object data?
I think that we have to use mgfeaturereder to read odject data, for this reason I link mgselectionbase:
Dim paths As FullSubentityPath() = e.Context.GetPickedEntities()
If paths.Length > 0 Then
 Dim ids As ObjectId() = paths(0).GetObjectIds()
If ids.Length > 0 Then
 Dim selId As ObjectId = ids(ids.Length - 1)
Dim selIdCollection as objectidcollection = nothing
sellidcollection.add(selid)
Dim MgSelBas as new mgselectionbase =  Autodesk.Gis.Map.Platform.Interop.AcMapFeatureEntityService.getfeatures(sellidcollectionl) ' after this line my Autocad Map 3D crashes
  End If
End If
Can we read data and show it on tooltips?
”Boost
