AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
.net Zoom to a selected point
2 REPLIES 2
newautocad123
598 Views, 2 Replies
How can I zoom to a selected point programmatically?
Thanks.
2 REPLIES 2
djonio
in reply to: newautocad123
Here is one way using COM. I just did a quick review and you might get an error if objectid is a Point object but this will get you going.
       static public void ZoomObject(ObjectId id, double zoomFactor)
            Database db = HostApplicationServices.WorkingDatabase;
            AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
            Point3d center;
            double zoomHeight = 0.0;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                object oMinpt = new object(), oMaxpt = new object();
                double[] dMinpt = new double[3], dMaxpt = new double[3];
                Entity en = (Entity)tr.GetObject(id, OpenMode.ForRead);
                AcadEntity en_com = en.AcadObject as AcadEntity;
                Object minPt = new Object(), maxPt = new Object();
                en_com.GetBoundingBox(out oMinpt, out oMaxpt);
                dMinpt = (double[])oMinpt; dMaxpt = (double[])oMaxpt;
                double heightEnt = dMaxpt[1] - dMinpt[1];
                double widthEnt = dMaxpt[0] - dMinpt[0];
                Object objRes = new Object(); objRes = app.ActiveDocument.GetVariable("SCREENSIZE");
                Point2d screenRes = new Point2d((double[])objRes);
                double aspectScreen = screenRes.Y / screenRes.X;
                double aspectEnt = heightEnt / widthEnt;
                if (aspectEnt < aspectScreen)
                    zoomFactor *= (aspectEnt / aspectScreen);
                center = new Point3d(
                (dMinpt[0] + dMaxpt[0]) * 0.5,
                (dMinpt[1] + dMaxpt[1]) * 0.5,
                (dMinpt[2] + dMaxpt[2]) * 0.5
                zoomHeight = heightEnt * 100 / Math.Max(zoomFactor, 1e-6);
            if (zoomHeight <= 0)
                zoomHeight = 1;
            app.ZoomCenter(center.ToArray(), zoomHeight);
 r,
dennis
newautocad123
in reply to: djonio
Thanks. It works as desired.
”Boost
