AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Mtext Rotation
2 REPLIES 2
Sgear
508 Views, 2 Replies
Mtext Rotation
Hi
I export from Argis into Excel I am try to get Rotation to the mtext when I import into Autocad
in the Excel file I got Angle from Argis
how can I use Angel to Rotation the Mtext in Autocad
acMText.Rotation = "-26.621873"  this is the Angle from Argis the Rotation is wrong if I use this number
Regards
Sgear
2 REPLIES 2
hgasty1001
in reply to: Sgear
That number looks like sexagesimal degrees (the common degree full circle equal 360 degress), but may also be a centesimal degree (full circle equal 400 degrees, surveryors  use it), try converting  to radians before pass the value to mtext.rotation property.
Gaston Nunez
Sgear
in reply to: hgasty1001
Thanks gasty1001
This fix my problem
        mtx.Rotation = angle * Math.PI / 180.0
Regards
sgear
”Boost
