Hi
I export from Argis into Excel I am try to get Rotation to the mtext when I import into Autocad
in the Excel file I got Angle from Argis
how can I use Angel to Rotation the Mtext in Autocad
acMText.Rotation = "-26.621873" this is the Angle from Argis the Rotation is wrong if I use this number
Regards
Sgear
Solved by Sgear. Go to Solution.
That number looks like sexagesimal degrees (the common degree full circle equal 360 degress), but may also be a centesimal degree (full circle equal 400 degrees, surveryors use it), try converting to radians before pass the value to mtext.rotation property.
Gaston Nunez
Thanks gasty1001
This fix my problem
mtx.Rotation = angle * Math.PI / 180.0
Regards
sgear
