I have layers that are connected to a spatial database (MSSQL and/or Oracle).
Because AutoCAD Map 3D caches all the data in a client side cache, I have to refresh the cache when data changes on the server side.
I know that I can use AcMapLayer.CreateCache() to recreate the cache. But because I have too much data, I can't recreate the cache every time, because it takes too long.
Is there a way to partially refresh the cache (e.g. by region or by adding objects manually)?
Or is there a way to fully deactivate the cache?
Markus
Hi Markus,
only two suggestions related to your question:
(1) - in Map you can refresh a layer (via context menu) - not sure if there is a API call for that. Instead of refreshing the cache - refeshing one or only few layers might be an option?
(2) - add layers/data to Map and apply a filter (spatial or attribute data) - this will decrease the amount of cached data.
Good Luck, Rob
Have you ever tried AcMapLayer::ForceRefresh Method? Does it work for you?
Hi Markus,
Are you using Map 3D industry Models(IM) or just "data connect" to MSSQL/Oracle spatial in Map 3D? If you can not using Industry Model, Map 3D data connection should take care of the caching stuff, and you do not need to call " CreateCache() " and "ForceRefresh()" will refresh the layer if you want to.
So to understand your situation, we need more information.
Oracle provides a way to indicate the primary key to expose for a view.
alter view <viewname> add constraint <constraintname> primary key (<columnlist>) disable novalidate;
For SQL Server, you can try to create a Unique Clustered index on the view in SQL Server. It would be something like this:
IF EXISTS (SELECT TABLE_NAME FROM INFORMATION_SCHEMA.VIEWS
WHERE TABLE_NAME = 'ANLY_BOMB_BLAST_MGE_V')
DROP VIEW ANLY_BOMB_BLAST_MGE_V
GO
create view dbo.ANLY_BOMB_BLAST_MGE_V WITH SCHEMABINDING
as
select
b.ID,
b.BOMB_TYPE_ID,
t.LONG_NAME as BOMB_TYPE_LONG_NAME,
t.TNT_LBS as TNT_LBS,
t.LETHAL_AIR_BLAST_DISTANCE_FT,
t.BUILDING_EVAC_DISTANCE_FT,
t.OUTDOOR_EVAC_FALLING_GLASS_HAZARD_DISTANCE_FT,
b.NAME,
b.DESCRIPTION,
b.ORIGIN_GEOMETRY,
b.LETHAL_AIR_BLAST_GEOMETRY,
b.BUILDING_EVAC_GEOMETRY,
b.FALLING_GLASS_HAZARD_GEOMETRY,
'Bomb Blast\nType: ' + t.LONG_NAME + ' (' + CONVERT(nvarchar(max), t.TNT_LBS) + ' lbs.)' AS TOOLTIPTEXT
from
dbo.ANLY_BOMB_BLAST b
inner join dbo.ANLY_BOMB_TYPE_LUT t on t.ID = b.BOMB_TYPE_ID
GO
CREATE UNIQUE CLUSTERED INDEX [ANLY_BOMB_BLAST_MGE_V_ID_IDX] ON [dbo].[ANLY_BOMB_BLAST_MGE_V]
[ID] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, SORT_IN_TEMPDB = OFF, IGNORE_DUP_KEY = OFF, DROP_EXISTING = OFF, ONLINE = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
GO
However, there are significant limitations to using the Unique Clustered index – no outer joins are supported. In this case, FDO Schema Overrides could be used to force the FDO Provider to use a specific view column as a primary key. See http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html.
I can't use "WITH SCHEMABINDING" in SQL Server, so the way to go should be "FDO Schema Overrides".
As I mentioned, I've already tried it out using the exact same approach like in MapGuide:
- FeatureSourceType.ConfigurationDocument = "config.xml"
- I added "config.xml" as RESOURCEDATA using ResourceService.SetRecourceData(), but that did not work.
I found out, that maybe Map 3D does not support RESOURCEDATA: "AutoCAD Map 3Ddoes use ResourceService.SetResourceData() for streams, but only for the configuration information for ODBC/WMS/Raster feature sources." (http://wikihelp.autodesk.com/AutoCAD_Map_3D/enu/2013/Help/0006-AutoCAD_0/0007-Resource7/0010-Differe...).
Then I've tried to save "config.xml" as local file, and that did work!
So I think I can achieve what I want!
It would be better if "config.xml" would be RESOURCEDATA, because otherwise I have to manage the files on my own.
Is there any way to to save "config.xml" as RESOURCEDATA, or is a local file the only way to go?
Thank you!
I'm currently fighting another problem, when calling ForceRefresh(pFeatureIds).
I get an Exception "Can not update objects" (in German), AcMapVectorLayer.ForceRefresh line 1616 file AcMapVectorLayer.cpp.
This is working for most layers, but for some layers I get this exception. I don't see what's wrong with these layers. All problematic layers have in common, that I use them to display "text only", but that should be no problem?!
Any suggestions?
Markus
You don't have to save config.xml locally, please refer to the sample "BuildMap" in Map 3D SDK.
Sorry but I am not clear about your meaning by "display text only", are you geting feature source and display some field as label? Since this topic is not related with the origianlly thread closely, so I would suggest you to create a seperate thread with detailed description.
Any suggestions?
Markus
