I want to write a lisp program to move the .labelpt of object data to the mid point of an arc. I would then run that on a bunch of arcs with object data and not have to do it one at a time.
The problem Im having is how to set the labelpt using lisp. Anybody know of any functions that would help?
Hello
To move the ADE Label Point to a specific point you can use the "ADETEXTLOC" command !
This command will create a XDATA Application "ADE" with the XY Coords of the NEW ADE Label Point , for example :
* Registered Application Name: ADE
* Code 1011, 3D World space position: (-0.8662 2.0333 0.0000)
I hope this will help you !?
Patrice BRAUD
