"Murph" wrote in message
news:11D43C6E2C710876BDE2CFDD431C24C1@in.WebX.maYIadrTaRb...
> Ok lets try it again.
> What is happening in MHO is that mapimport4 can not read the new arcMap8.3
> format (it did come out after Map5 right?) So it doesn't understand all
new
> file type. What I would do in lisp is one of two different options.
> 1. Use a import profile and call that in the lisp -mapimport command. Now
if
> you are wanting to bring in different shape files with different data that
> may not work. Unless you create the ipf file in lisp which might be more
> trouble than it's worth.
Yea, that wont work because the IPF file holds the config for all the files
in the directory specified, which in my case, changes all the time. If the
IPF file only contains data for one shape file, the rest are imported with
default settings. Very annoying. This is the least elegant solution at this
point.
> So option 2
> Use vl-copy-file to copy the shp,shx, dbf files to a temp folder. import
> then use vl-delete-file to delete the files (shp) after they are import.
This was another option, exporting each request, which consists of many
shape files, to a unique folder. This option is beginning to look better all
the time. Its either this or get ArcToolbox to convert the shape files to
coverages and use our existing coverage import system.
The whole scheme is that the user request the data, a process on another
computer with arcmap installed generates the shape files in the specified
area, and the cad system integrates the shape files into the drawing once
the request is finished processing. Lots of riff-raff to go through....
-A
