Hi Everybody,
Has anybody run into this problem:
I have a drawing with a link template linking drawing objects to an external Microsoft Access database. One of the columns in one of the tables is defined as a LONG INTEGER.
Whenever I do a MapExport to an ESRI Shapefile, AutoCAD Map 3d 2008 converts the LONG INTEGER to a DOUBLE.
How do I stop it from doing this?
Helllpppp!!!
Thanks in advance for any help you can provide.
