AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Map Cleanup
1 REPLY 1
gsktry
766 Views, 1 Reply
Map Cleanup
I am using the attached lisp routine to cleanup the entities, which should work on the selected entities only. But, it cleans all the entities in the dwg. Am I missing anything in the routine?
Siva
1 REPLY 1
gsktry
in reply to: gsktry
I got it. I have to call (tpm_varset var_id "INCLUDEOBJS_AUTOSELECT" 0)
”Boost
