AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
LIve Maps GEOREORIENTMARKER
0 REPLIES 0
Message 1 of 1
218 Views, 0 Replies
I have a need to use the GEOREORIENTMARKER command programatically. If you issure the command without first going through the geographic location wizard, it will present you with a dialog box. Setting the latitude/longitude, and northdirection sys vars do not work.
0 REPLIES 0
”Boost
