AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Layer.UpdateFeatures(); Layer.SaveFeatureChanges() is Slow
2 REPLIES 2
troy.miller
537 Views, 2 Replies
I am working with the AutoDesk Geospatial platform API to connect to a SQL2008 spatial database. I have my application working but whenever I try to add/update features and save the changes it takes a long time. It takes about 5 seconds which making a user wait five seconds to add a feature is too long.
Is this the right approch to add features or is there another method to update features and then save to the database?
Here is a section of my code:
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
commands.Add(new MgInsertFeatures(MyPointLayer.FeatureClassName, propcol));
MyPointLayer.UpdateFeatures(commands);
MyPointLayer.SaveFeatureChanges(options);
Any insight would be appricated.
-Troy
2 REPLIES 2
kob4lt
in reply to: troy.miller
I think you don't have to call SaveChanges method on layer and did you try updating features like this
AcMapFeatureService fs = AcMapServiceFactory.GetService(MgServiceType.FeatureService) as AcMapFeatureService;
fs.UpdateFeatures(new MgResourceIdentifier(layer.FeatureSourceId), commands, false);
troy.miller
in reply to: kob4lt
I found a documentation site that explains this.
http://wikihelp.autodesk.com/AutoCAD_Map_3D/enu/2012/Help/0000-AutoCAD_0/0015-Feature_15/0029-Updati...
I tried the featureservice method but the problem is AutoCAD does not update the layer correctly. It saves the data to the datasource but then AutoCAD re-overwrites it and I end up losing data.
After my command to updateFeatures I would have to refresh each layer which takes longer then the "Edit Set" method from the above link.
”Boost
