With AutoCAD Map I am connected to this SDF source. While I am connected, through code I am opening and closing same SDF file with FDO. This works fine, but, when I insert a feature with code, everything goes well but AutoCAD Map doesn't see this change. Even if I refresh layer, nothing happens. When I look at the file, I can see that it has been modified.
When I disconnet from the source and then connect back, that feature is here.
If I do the inserting all again (after connecting and disconnecting), everthing goes well
Help! I am going crazy
So if you made some insertions of new features with your code and you try to close the DWG ==> do you get the request for commiting the changes? If so you should "commit the insertions" within your code.
Or how do I have to understand "Map doesn't see this change"?
- alfred -
No i don't because, i think, i am directly accessing SDF with FDO, not with Map.
Sure? So whatfor do you start Map3D then if you write directly to the SDF-file?
I think you use the Map/MapGuide/FDO-Library to insert new objects into the FDO-connected SDF. And that made me requesting if you commited the changes by code or you get a request for commiting/check-in the new FDO-objects.
Once more: if you don't get the request for that, how do I have to imagine your words "Map doesn't see this change"? Did you assign new features to the sdf and you don't see it on the display? If so: what happens if you pick "refresh" from the right-mouse context menu on your GIS-layer in the Map3D-Workspace? (hoping "refresh" is the correct translation from my German Map3D)
- alfred -
I was expacting that accessing features through FDO is faster than accessing with Map/MapGuide/FDO-Library
Yes, that it's exactly the point, when I pick a point in drawing and insert feature with FDO (IInsert method), feature is not displaying in drawing. Than I hit the refresh button (right click on that layer in MAPWSPACE palette) -> nothing. I go to my computer, to that sdf file, and in the properties window I can see that it has been modified within a minute ago.
Then, I disconnect from SDF and connect again, that insert feature is there, it is displayed now.
So, what I mean by "Map doesn't see changes" it means that Map connection doesn't register that sdf file has been modified
And after reconnecting, inserting features is working fine, when I insert feature, it is there, within a second in drawing
One question. after Execute method on insert object, do I have to do anything else?
look to my code-snippet (short and just out of an application), may be it helps (as it works for SHP-files via FDO)
If (tFdoBatchPropColl IsNot Nothing) AndAlso (tFdoBatchPropColl.Count > 0) Then Dim tInsertFeatures As MgInsertFeatures = New MgInsertFeatures(tFeatureClassName, tFdoBatchPropColl) Dim tFeatCommands As MgFeatureCommandCollection = New MgFeatureCommandCollection tFeatCommands.Add(tInsertFeatures) Try Dim tFdoResultProps As MgPropertyCollection = tFdoLayer.UpdateFeatures(tFeatCommands) Dim tQueryOpts As MgFeatureQueryOptions = New MgFeatureQueryOptions Call CType(tFdoLayer, AcMapLayer).SaveFeatureChanges(tQueryOpts) tFdoLayer.ForceRefresh() Catch ex2 As Exception Call ISHMessaging.MessageAdd("Fehler bei Export nach FDO", "ISH.ISHFdoConn.writeEntsToFDO", ex2) tRetVal = False End Try End If
Especially the .ForceRefresh may be the missing link for you?
- alfred -
Do you think that it is better to work with MapGuide or FDO library? Is there a difference?
As long as you start them within Map3D there is no difference (they are coming more and more close to each other).
A difference would be (what I thought first) to use any free API's from www.osgeo.org (or any partner) ....while you have loaded it in Map3D.
- alfred -
