When you break a line with object data tables, one part of the line will keep all the object data tables.
The other part will be seen as a new line without object data tables.
Is there some kind of setting that will automatiically copy all object data tables to the new part of the broken line?
Thanks in advance!
Anwar
You must find in support\ folder this aplication copy_od.lsp, load it.
Albert
