AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Inherit objectdata when breaking a line
3 REPLIES 3
ivt209
607 Views, 3 Replies
When you break a line with object data tables, one part of the line will keep all the object data tables.
The other part will be seen as a new line without object data tables.
Is there some kind of setting that will automatiically copy all object data tables to the new part of the broken line?
Thanks in advance!
Anwar
3 REPLIES 3
kalman_albert
in reply to: ivt209
You must find in support\ folder this aplication copy_od.lsp, load it.
Albert
"Nothing will ever be as it was!"
fieldguy
in reply to: ivt209
Check out the drawing cleanup tools.  The "break crossing objects" action preserves od.
ivt209
in reply to: ivt209
Hi Albert,
Your suggestion works perfectly for me.
Many thanks!
Anwar
”Boost
