Hi All,
First time i am working on 3D data(It means z axis) in AutoCAD ,net. I have some gas lines in Map3D whcih means 3d data.
I could not able to do selection set, closest point etc on 2d features. i am getting invalid outputs.
How to handle the 3d entities in AutoCAD .net?.
Thanks in advance.
Dayalan
Hi
Still i don't get any solution.
My original problem is, getclosest point returning wrong result.
1. I am picking a point on a line using nea snap.
2. trying to use polyline.getclosestpointto(pickpoint, false)
3. The resultant point is should be on top of the polyline. but my result not on a line. result point is placing some where long distance.
one more point is my drawing is on AutoCAD Map3D 2013 format, i opened this drawing in AutoCAD Map3D 2014 and using AutoCAD Map3D 2014 API
Any help much appriciated.
Dayalan
