AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
How to Export a drawing to a 3D DWF file using VB. Net
1 REPLY 1
613 Views, 1 Reply
Does anyone have code for creating a 3D DWF file from a drawing using VB.Net?  I have program that processes several hundred drawings, and creates a PDF, a DWF, and I want it to also create a 3D DWF.
I've not been able to find anything on performing an Export.
Ken
1 REPLY 1
Hi Ken,
Try using DSD file and Autodesk.AutoCAD.Publishing.Publisher.PublishDsd API.
Check the following blog post in our AutoCAD DevBlog -
http://adndevblog.typepad.com/autocad/2012/05/how-to-use-the-autodeskautocadpublishingpublisherpubli...
Hope this helps,
”Boost
